V70 2.4 120kw hemarojus
Scriptor
Pranešimai: 106
Užsiregistravo: 2009 Geg 18 15:15
Auto: s40
Standartinė Scriptor »
Turiu tokia beda, gal padetumete ispresti :)
V70 2008m 2.4D 120kw euro 4
Susilusios masinos ijungus laisva pavara pulsuoja apsukos ir is reto uzgesta masina :(
Per diagnostika ispete klaida P000100 Fuel Volume Regulator Control Circuit / Open
Paiskinimai:
*Fuel volume control valve (VCV) circuit high resistance
*VCV circuit open circuit
*VCV failure
An open circuit will prevent the engine from running.
Refer to the electrical guides and check
the fuel volume control valve and
circuits. Check the resistance of the
valve and install a new high pressure
fuel pump if the resistance is not
between 1.5 and 15 ohms (the fuel
volume control valve cannot be
serviced separately). Clear the DTCs
and test for normal operation. Refer to
the warranty policy and procedures
manual if a HPP is suspect.
Taip ir nesupratau ka cia reikia keisti ar tvarkyti :kolobki2_read :s07
Butu kokiu minciu? :kolobki2_big_bosslogin to view the rest of this post
This topic has 10 replies
