xc70 greiciu dezes beda
Danas123
Standartinė Danas123 »
Sveiki.
Auto XC70 2001 147 kW benzinas. Pravaziavusi 150000 km.
Pradejo mesti klaida "Transmission service required". Pasidariau "Itodoj" diagnostika. Rezultatas:
TCM-012B Neutral check No check
Condition
The driving section of the gearbox is disengaged when certain conditions are met:
*Stationary
*Engine idling
*Stop pedal depressed
*Gear position D, 3 or 4.
The function decreases fuel consumption and vibration from the gearbox when running the engine at idle speed.
Diagnostic trouble code (DTC) TCM–012B is stored if the gearbox control module (TCM) registers that clutch C1 does not engage.
Substitute value
-None.
Possible source
-Shift solenoid SLS has jammed in the OFF position
-Internal fault in the gearbox
-Internal fault in the control module.
Fault symptom[s]
-General orange warning lamp lit
-Malfunction indicator lamp (MIL) lit.
Jokiu trukciojimu, bildesiu ar pan. nera, nu nezym…login to view the rest of this post
This topic has 2 replies
